Windchill FTA - updating calculation data from library
MMonfalcone
I'm trying to use the FTA Event Library to organize event calculation data parameters for multiple similar but independent events.  I want these events to use the same calculation data but have different descriptions.  I have my calculation data saved in the FTA Event Library but when I go to update events (after I update the failure rate data, for example) it overwrites the data AND the description of the event.  How can I just update the calculation data from a library event?
Hi MM_4454300,
Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
MMonfalcone
(To:anursingh)
So one of my events looks like this:
I have an FTA event library event called "Effectiveness: Low" and I have multiple events in a large fault tree that use that model.  When I update the library event, I want to be able to update all events with the Library Identifier "Effectiveness: Low."
What's the best way to do this?
