Windchill Integration with Codebeamer
NS_10797603
7-Bedrock
I wanted to integrate windchill with codebeamer, so as of now I'm trying to integrate through API, while connection to windchill I'm not getting the session jar files in the codebase folder of eclipse. Can anyone suggest how can I get jar files or how can i do the integration with API bcz we r suggesting doing without OSLC.
7 REPLIES 7
Hi @NS_10797603,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
HelesicPetr
(To:NS_10797603)
Hi @NS_10797603
You have to set the libraries in your Eclipse environment You need to add the jar files manually if they are not added automatically.
Here is an example from InteliJIdea
PetrH
Hello NS_10797603,
It looks like you have a response to your topic. If it helped you solve your question please mark the appropriate reply as the Accepted Solution.
I'm trying to integrate codebeamer with windchill using DTP and I'm attaching the link( codebeamer DPT Integration ).
I'm not able to get the proper steps for server guide for Content Security Policy and for client guide also , need proper steps to proceed with further ssteps if any other then wiki link , plz guide me on this.
HelesicPetr
(To:NS_10797603)
I would suggest to use DPT for the integration, it will save your time and reduce the complexity and risks.
Refer to the below article for PDMLink as OSLC server and Codebeamer as OSLC client.
https://www.ptc.com/en/support/article/CS400634
nimish_gopal
(To:NS_10797603)
Hi @NS_10797603
Integrating Windchill with Codebeamer via APIs can be challenging—especially when you're dealing with authentication, session handling, and tool-specific dependencies like JARs. Here are a few things to consider:
Why Building Your Own Integration Can Be Problematic:
  • Tool Complexity: Windchill and Codebeamer both have deep, structured data models—mapping entities correctly (e.g., parts, BOMs, change requests) isn’t straightforward.
  • Authentication Challenges: Windchill uses session-based authentication. If JARs or environment configs are missing, establishing a session through custom code becomes unreliable.
  • Maintenance Overhead: Any API changes, version upgrades, or field structure updates can break your custom logic—leading to fragile integrations.
  • Traceability Risk: Custom integrations often miss relationships, attachments, or change history—making traceability and audits harder.
Why Consider a Purpose-Built Integration like OpsHub:
  • Out-of-the-box support for Windchill and Codebeamer (no OSLC dependency needed)
  • Federated sync of structured data, workflows, and hierarchies across both systems
  • Maintains context, traceability, and change history automatically
  • No manual handling of sessions, JARs, or authentication—OpsHub handles it securely
  • No plugins or performance drag on either system
Drop us a line if you want to learn more.
