When we configure from installation Windchill 11.0 M030 with MSSQLSERVER. We get an error.
We attached log file about the problem.
Thank you
For some reason the installer can't find the file called 'CreateDB_large.sql'.
>>>> START Create SQL Server Database for Windchill <<<< STDOUT: STDERR: Sqlcmd: 'C:\ptc\Windchill_11_4\SQLServer\Conf\CreateDB_large.sql': Invalid filename.
Probably best if you open a tech support case with PTC.
[You might want to be careful with log files like this. They include all the passwords in plain text...]
Thank you. I gave an answer from PTC. I shouldn't install Windchill 11.0 on MSSQL Server 2008.
This installation was educational purpose, so this isn't problem but I mind that passwords issue.
