Hi Guys,
I am looking for a CAD compatibility matrix for Windchill 11.0 M030 CPS 22. If any one has kindly shared with me.
Aj
I do have an older version of the matrix that clearly shows Windchill 11.0 M030 is only supported up to Creo 6, as I listed in my comment above. I was looking at that chart when I wrote my earlier response.
Like jbailey said, Creo 7 may work, but it is not supported with Creo 7.
thanks for the replay @avillanueva
which Creo Parametric we can use in Windchill 11.0 M030 CPS22.
Aj
Thanks for the replay @jbailey How we can find it like if it's CPS 10 which version of Creo we can use and CPS22 which one we required like that. How we can find it.
Aj
This is probably the best matrix you are going to get...
https://www.ptc.com/support/-/media/support/refdocs/Pro_INTRALINK_8,-d-,x/11,-d-,1/WindchillCreoSWCompatibility11x_168117.pdf?sc_lang=en
sorry to say here i can only see upto CPS 14, i want CPS22 also
Creo 6.0 support with Windchill 11.0 requires as a minimum Windchill 11.0 M030 CPS14 refer page 12.
Aj
You can use any release of Creo 6 with Windchill 11.0 M030 CPS14 and higher. Your use of CPS22 will be fine with any release of Creo 6.
You cannot use any higher versions of Creo with Windchill 11.0 M030.
To use a higher version of Creo, you will need to upgrade Windchill.
Windchill 11.1 can be used with Creo 7 & Creo 8, along with Creo 6.
Windchill 11.2 is the same.
Windchill 12.0 removes support for Creo 6 and adds support for Creo 9 and Creo 10.
Thanks for sharing @BenLoosli
But i thing we can use Creo 7 also but i can't find any matrix for that.
Aj
It may work, but it is not supported.
