Windchill PDF/DXF export file name
mbonka
Hello all,
our company is implementing Windchill and l wanna ask you about drawing exports. Our saint rule in WCH is: EACH FILE ONLY ONCE!
But up to now my praxis was fallowing: During the project progress l exported PDF, send it to my chef via email, afterwards he marked some changes and send it back to me. l made all necessary changes and the circle continue again and again ...
25.2.2014 --- export drw to PDF and saved it to sudirectory ...export / 2014_02_25 / 15009_V01-00_00_00.pdf
30.2.2014 --- export drw to PDF and saved it to sudirectory ...export / 2014_02_30 / 15009_V01-00_00_00.pdf
My first question is: What name schema for exports (PDF, DXF) should l choose?
1. Show a revision and version of source drw? ---> 15009_V01-00_00_00_A1.pdf ---> don´t think it´s a good idea
2. Show a datum of creation? ---> 15009_V01-00_00_00_2015_02_30.pdf ---> don´t think it´s a good idea ---> if l will do 2 exports in same day, it will doesn´t work
My second question is: What are your expiriences and praxis with file naming?
Thx all for ideas...
mbonka
(To:mbonka)
Well at last!!!
Generall documentation don´t have to be unique name. This "saint rule" is only for CAD documentation.
My solution:
Result:
The day when l learn nothing is lost
unickque
(To:mbonka)
This question will probably get more answers if it were asked in the Windchill forums
l know, but l´m not able to pass it into Windchill forum section.
Could someone redirest my topic into apropriate section?
Mahesh_Sharma
22-Sapphire I
(To:mbonka)
Milan,
Moved the discussion to Windchill.
mbonka
(To:mbonka)
Well at last!!!
My solution:
Result:
