Dear All,
Our users currently facing the issue mentioned in the below SPR:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS134791
We tried the below work-around:
For Windchill PDMLink 10.0 and 10.1 :
Add the following text to the end of the file %WT_HOME%\codebase\netmarkets\javascript\util\windchill-all.js
executeCancel = function() {};
Note : this change is temporary and will be lost in the next patch install or when running the combine command (ant -f jsfrag_combine.xml)
(b) On the client:
It did not helped our usres.
Did any one of you faced the similar kind of issue?
Thanks & Regards,
Ravi Kandepu
