Folks,
Sincerely,
Dan J. Dial
314 378 5922
That is the way Windchill works. It is working as designed.
The reason it goes to the local workspace and does NOT do an automated download from the server is to allow you to experiement with different iterations and still share the changes with your workgroup.
The internal web browser would show that you did not have the latest iteration in the workspace and you should have then downloaded them to continue working with the latest changes.
If you are having problems with overriding the workspace iteration with the latest iteration in commonspace, then that may be an issue of configuration or a bug.
