Hi All,
I have built a Virtual Server using Windows Server 2003, MSQL 2008, Sharepoint 3.0 and WPP 1.1 M021. The problem I'm having is logging into ProductPoint from a client on a different domain and wondered if anybody has come across this or has any suggestons?
Paul
Hi Paul,
I had the same problem. I reason was, that the WPP Admin User, who managed the user, don't have access to the domain of the user. So it is not possible to add the user to the web application WPP ...
A solution is, that the WPP admin is a member of the same domain like the user who will get access to WPP.
Regards Frank
Hi Frank,
Basically there is an issue with Server 2008, Share Point 3.0 authenticating with Windows 7
This can be found on the net, but I'm still waiting for a resolution as people will be moving to this hardware spec in the future.
Windchill ProductPoint is supported for use in virtual environments. Actually, many fo the PTC QA servers are VMWare servers, so not only supported but well tested.
