Windchill Promotion PDF File Settings
jwheeler
Does anyone know how to change the pdf export settings for a promotion in Windchill?  Currently all pdf's are showing the drawing view display in wirefarme format.  I do not have this issue when I create pdf's locally off of Windchill.  Looking for a config setting that creates pdf's with all drawing views in no hidden drawing view format when in Windchill.
Jim
BineshKumar1
(To:jwheeler)
You should make this configuration change in the CAD worker machine. The Creo in CAD worker should have the same config.pro settings as what you have locally.
Binesh
Barry Wehmiller
