Is there a way to connect the Windchill Risk & Reliability (or WQS) tool to Silicon Expert database in order to pre-fill most of the component parameters (Thermal resistance, voltage rating etc…)?
Is the built-in database is up to date?
Is there a tutorial to build automatically a board assembly based on manufacturer part number by using the built-in database?
Thanks for the information.
Do you know how to install the extension (.wexb)?
Take a look - "Deploying/Undeploying a Windchill Extension": https://windchill-extensions.ptc.com/kb/articles/installext
Do I need to get install the ''Manage Platform" sofware before I install Extensions?
See below for the Windchill Extension Platform Installer:
https://windchill-extensions.ptc.com/kb/articles/installing-the-windchill-extension-platform
Where do I get the Manage Planform because it did not apear on the https://windchill-extensions.ptc.com/ web page?
I managed to download the Manage Platform but i have the following error message when I try to install it:
