In the flow, I need to write a code to send it to more than one user for approval, so that the task continues after each user gives approval. Can you help me with this?
Easy, you need to add multiple participants to the task. Make sure that required is checked. Which means each line needs to take action. There is a lot of information on this in help docs: https://support.ptc.com/help/wnc/r12.0.2.0/en/#page/Windchill_Help_Center%2FWFTabAactPtcpnt.html%23wwID0EUDPY
