Windchill Server Domain name change.
bkontham
We have changed our Windchill Server domain name from df-wc-test.hs.local to df-wc-test.dfinc.hs.com.  Updating the Repository entries, Web Server host name entries, Windchill entries and Directory host name server entries will work? Please let me know if there are any additional steps to be performed.
Cat
(To:bkontham)
There is Widchill Rehosting Utility.
Enhancement Details: Windchill Rehosting Utility - PTC.com
BineshKumar1
(To:bkontham)
You need to update the LDAP conf branch. If you are not using re-hosting utility, you need to update the LDAP name
ant "-Dtarget-ldap=ldap://<LDAPAdminUser>:<LDAPAdminPW>@<newHostname>.<oldDomainName(Constant)>:<ldapPort>/" -Dtarget-domain=<newHostname>.<oldDomainName(Constant)>
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS99222
It sounds like you have everything.  I would double check in the Rehost guide.  This is basically a rehost.
Sandra
