Windchill Shell is launch failing.
KR_10374544
substr outside of string at windchill line 355.
Use of uninitialized value in hash element at windchill line 357.
Use of uninitialized value in scalar assignment at windchill line 357.
Use of uninitialized value in hash element at windchill line 358.
Use of uninitialized value in scalar chomp at windchill line 322.
Use of uninitialized value in index at windchill line 336.
Use of uninitialized value in substr at windchill line 336.
Use of uninitialized value in index at windchill line 337.
Use of uninitialized value in substr at windchill line 337.
Can't spawn "cmd.exe": No such file or directory at windchill line 383.
8 REPLIES 8
Fadel
23-Emerald I
(To:KR_10374544)
KR_10374544
(To:Fadel)
COMSPEC at the system level is good. But no Luck!
ANNA_02
(To:KR_10374544)
Check out the following articles,
https://www.ptc.com/en/support/article/CS312422 - if it is a space issue
or
https://www.ptc.com/en/support/article/CS105560
error logs mentioned above matches these 2.
KR_10374544
(To:ANNA_02)
Space Issue is mentioned for the Linux Environment.
Checked with IT and got no luck.
I am trying to find some other solution. Need some help.
Is there any other solution, or any idea why the shell is not working?
Can you try with this command from the command prompt with admin privileges.
WT_HOME\bin\windchill.exe -w "WT_HOME" --java="JAVA_HOME\jre\bin\java.exe" shell
WT_HOME and JAVA_HOME are replaced by the actual path of by %WT_HOME% and %JAVA_HOME% . You can set these variables first.
Hope this helps.
regards
~Syed
KR_10374544
(To:shussaini)
No Luck!
D:\ptc\Windchill_12.1\Windchill\bin\windchill.exe -w "WT_HOME" --java="D:\ptc\Windchill_12.1\Java\jdk11.0.16_9\bin\java.exe" shell
Check if this helps.
