Windchill System Parameters in Drawings
TomU
Certain system parameters are mapped from Windchill to Creo (see picture below). Others are not. How is this controlled?
I'm specifically trying to determine how to read/display 'Name', 'Number' and 'Filename' from Windchill. REL_MODEL_NAME can be used to set a parameter equal to the Creo filename, but is there a way to read the Windchill 'Filename' parameter directly. I also realize that 'Name' maps to 'PTC_COMMON_NAME' (or at least used to), but this is a hidden "reserved" parameter in Creo. I can't create it or display its value. Any idea how to read the Windchill 'Name' and 'Number' parameters directly in parts and drawings? Thanks.
Tom U.
[cid:image001.png@01CEBF58.9475ABD0]
TomU
(To:TomU)
dgraham-4
(To:TomU)
Tom,
You can still display PTC_COMMON_NAME like any other parameter
&PTC_COMMON_NAME or &PTC_COMMON_NAME:D.
David Graham
Windchill Developer/Administrator
CAx Administrator
Emhart Glass Research Center
123 Great Pond Drive | Windsor, CT 06095 | USA
Telephone +1 (203) 376-3144 | Telefax +1 (860) 298 7397
Mobile +1 (203) 376-3144 |
