Windchill Upgradation from 10.1 M010 to 10.2 M020
pvna
Dear All,
I'm trying to upgrade windchill from 10.1 M010 to 10.2 M020 in my test server.
For that I've followed below steps.
  • I've set up source system in which windchill PDM link 10.1 M010 installed.
  • Installed required patches for this.
  • Exported LDAP and Database(Oracle 11g).
  • Later, I've set Target system for upgradation.
  • Note : Here source and target systems are on same machine.
  • Performed WINDU in source and got results in successfull.
  • After, installed 10.2 M020 in target system through PSI.
  • Note : Here, used existed database while installing.
  • After successfully installed 10.2, imported LDAP successfully from Source to target.
Now, I'm trying to perform UpgradeManager task but facing error at Database path phase . I'ts asking Oracle schema user and role name and I'ven't set them while installing. So, I manually created these two and granted all permissions. But, tit shows that these valuese are not properly considering by UpgradeManager.
I'm performing Windchill Upgradation for the firs time.
Request you to please guide me to overcome this problem.
Thanks in advance.
GaryMansell
(To:pvna)
You need to install your 10.2 System into a new (temporary) DB schema to install the fresh 10.2 installation and then later the update_tool is used to update your old 10.1 DB schema to suit 10.2 and it is then used with the 10.2 Application loadpoint - they old 10.2 DB is then no longer needed and can be discarded.
Rgds
Gary
Dear Gary
Thanks for your reply...
I wil reinstall 10.2 in the different schema of existed database.
I'll ill be touch with you .
