WT Part has 3D CAD normally.
But sometimes Detail and Structure Tab's visualization doesn't work properly.
There is a continuous loading phenomenon.
1`. Detail Tab's Visualization
2. Structure Tab's Visualization
Someone see this phenomenon Or how to fix this?
HI,
If this is a recently seen issue it could be related to https://www.ptc.com/en/support/article/CS000384616
If the above is not the issue you may need to investigate per https://www.ptc.com/en/support/article/cs265116
Vishwas
Hello @Aden ,
I found following documentation about Visualization tab:
https://www.ptc.com/en/support/article/CS248643
Do you use Edge browser ? latest version ?
Is your Part a big assembly with lots of components ? do you have 3D representation of each component ?
Do you have same behaviour with CAD Document linked to your Part ?
BR,
Pascal
Hello, Pascal
it doesn't work the structure tab's refresh button.
And we use Windchill 12.1.0.0+ and Chrome(latest version), Edge.
After more research, I think the problem occurs in the latest versions of Chrome and Edge.
Is your Part a big assembly with lots of components ? A: No. when i see the only part, it doesn't works.
do you have 3D representation of each component ? A: Yes, I have.
Do you have same behaviour with CAD Document linked to your Part ? A: Yes, the parts are linked normally
Thank u for replying my question, Pascal
HJ
HI,
Vishwas
Hello Vishwas
I saw your answer and I think browser's latest version makes problems.
So, I will downgrade my browser or using other browser.
Thank u for replying my question, Vishwas
HJ
