After performing Save Bodies in SOLIDWORKS, the new/derived files does NOT appear in the workspace table of WGM
However, the files can be found when browse using File Explorer
The files will only appear if they are opened and saved again manually
What might be causing this issue?
Edit:
The same issue also happens when performing a Save As Copy
Did you find a solution for this issue?
I am running into the same issue.
No i did not..
