Windchill admin login Utility menu not display
PC_10366408
6-Contributor
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.3
Here are the errors that I faced
You may want to try testing your authentication using the wt.auth.Authentication utility. Instructions in the ticket:.
https://www.ptc.com/en/support/article/CS338401
Is this a new install or an upgrade? Could be a license issue with the admin user. Send more info.
Hello PC_10366408,
I'm Charles from PTC Technical Support in Europe: Was the information provided helpful somehow?
KR,
Charles.
