HI all,
We are trying to load extracted data of WBM EXTRACTOR from source Windchill 11.1 cps 14 to Windchill 11.1 cps14 from Staging database of loader.
I have run this command wbmldr -s EPMDocumentMaster in winchill shell.
I am getting this error in WBM Loader logs.
Please check for the DB connection details provided...
20/07/2022 15:05:10 ERROR db.DSHandler - Unknown datastore: 2
com.ptc.wbm.wbmldr.util.WbmldrError: Cannot initailize com.ptc.wbm.wbmldr.core.db.DSHandler
Read the following article - "wbmldr -help command throws error exception occured while fetching the database type in Windchill Bulk Migrator": https://www.ptc.com/en/support/article/CS354249
Hi ,
i have checked the db contains DBtype sqlServer which is we are using.
Kishore M
