Article - "[Knowledge Hub] Windchill Bulk Migrator WBMFF": https://www.ptc.com/en/support/article/CS319432
Hello @NJ_11253659,
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
I want to install WBM to my existing version. Which is the CPS that I should use for the same to get the upgraded version with WBM installed? Current version is: 11.0 M030-CPS22
