Windchill in a Virtual Machine
hamzaboudouira
I have retrieved Windchill installed on a virtual machine, and Arbortext Editor is inslatteld in a physical one.
So the virtual machine runs in the same physical machine.
I want integrate Epic with Windchil by modifying the "siteprefs.xml" file in the adapter and put the IP adress of waindchill's machine. but Arbortext Editor can't connect to windchill.
I don't no if someone has already done this configuration.
I'll be greatful if you help me
Cordially
As first step, you can remove Arbortext out of picture.
Try to connect from a Browser (from Physical) to VM Windchill and see what happens. (Try only hostname without Windchill context)
If that works then try http://<hostname>/Windchill and during that time if its not coming up, try adding the ip/hostname in you hosts file and see if that helps.
Also, do a IP config in physical/VM and see how the subnet setup is.
I am using Windchill 9.1 and Arbortext Editor 5.4.
the communication between the two machine(virtual and physical) is good, because I have done a ping to verify.
the problem is the communication between arbortex and windchill
Best Regards
1. Physical Machine holds
2. Arbortext
3. Windchill VM
Are you saying 1 can't talk to 3 or 3 can't talk to 1 or both?
I've had problems getting images to talk to their parent physical machines. I'm not a networking guy, but... try an alternate IP and have your router forward to the correct image/physicalbox.
hello everybody,
i have resolve the problem, i've write a documentation wich illustrates steps of the configuration
but this doc is in french, i sorry but my office abligate me to write in french, so if someone can translate it and republishs it i'll be happy
this my email if someone want more informations : -
Cordially
