Windchill installation error
atemnikov
7-Bedrock
Hello.
I tried to install Windchill 10.2, but got an error. Log file contains these lines before exception stack trace:
DEBUG  2015-12-01 14:32:24 - setupWindows:
DEBUG  2015-12-01 14:32:43 - [exec] Server Already Configured
DEBUG  2015-12-01 14:32:43 - [exec] setup.bat command-line can only be used with servers that have not yet been
DEBUG  2015-12-01 14:32:43 - [exec] configured.  The current server:
DEBUG  2015-12-01 14:32:43 - [exec] - Contains data
DEBUG  2015-12-01 14:32:43 - [exec] - Has already been configured
DEBUG  2015-12-01 14:32:43 - BUILD FAILED
OS is Win 8.1. What should I do?
Thanks.
Andrey Temnikov
The error is thrown by WindchillDS installer. Do you have a previous failed install of Windchill? If you are re-running installer after a failure, make sure WindchillDS is started. Try using a different directory for the installation of Windchill
Thank you
Binesh Kumar
BenLoosli
(To:atemnikov)
It looks like Windchill has previously been installed on that computer.
Delete the Windchill folders.
Use REGEDIT and remove any references to Windchill, Tomcat, Apache and JAVA that were in the old Windchill install path.
Reboot and Reinstall
Thank you
Binesh Kumar
There were no any previous installations, but when I deleted Windchill directory and choosen another local disk, installation was continued. Thank you!
Best regards,
Andrey Temnikov
