could you give me a hint ... I am looking for a table to see,
which mksapi.jar version requires/supports which JDK version / is used for testing by PTC.
I ask because we are not sure if JDK 8 is required/supportet or if we can also use JDK 11..
We use Windchill .v12.4 and access its API via mksapi-jar-4.16.2671.jar .
Thanks for your support.
Ron
Yes, good idea 😉 I opened a case at PTC ...
PTC suggests to use JRE v8.x matching to the used Operating System also for the java-program using mks-api.jar
At the moment newer JRE versions >8.x are not certified (meaning that there were no tests performed by PTC team on those versions).
Windchill 12.0.2.0 Software Matrices | PTC
From that document, only 11.0.11 is the tested release.
Java 8 was good for all release of Windchill 11.x.
Thanks a lot for your fast response with the linked Windchill 12.0.2.0 Software Matrices | PTC , That's what I was looking for!
I would interpret
if *Java (JDK 11.0.11 ) is a required component for the Windchill server"
I shall also it, when I access the server API via mksapi-jar-4.16.2671.jar.
Means I shall prefer JDK 11 and do not use JDK 8
Right?
Thanks in advance!
Sorry just noticed: I need to add:
We use Windchill RV&S v12.5 and access its API via mksapi-jar-4.16.2671.jar .
Unfortunately RV&S is not mentioned in Windchill 12.0.2.0 Software Matrices | PTC but other Windchill products ... right?
In most cases the underlying Windchill is the same, just the application is different built on the base Windchill toolkit.
I would think that all Windchill 12 products would then require JAVA 11.0.11+.
hm - it seams to be a difficult think. I found Windchill® RV&S 12 Product Platforms
https://www.ptc.com/support/-/media/support/refdocs/Integrity_Lifecycle_Manager/12,-d-,0/Integrity_Lifecycle_Manager_12_Product_Platforms.pdf
in chapter "Java Support":
only Java JRE v8 Editions are supported for the Windchill® RV&S 12 server.
Well the server, but there is nothing written about
what Java-Version shall be used for the mksapi-jar for API access to the Server ...
I also could not find anything in the Java-doc of the mksapi-jar , what java was used for testing it 😕
My suggestion is to open a help desk ticket and ask that question. TS should know what JAVA version is required.
