I am new to PTC and Windchill and do have one question that I cannot seem to find an answer for, perhaps one of you can tell me. We were informed by a local support person that PTC Windchill will be going away from the Java programming language in a coming release, is that true and if so what will be the new programming language of PTC Windchill? Thanks
Dennis Hamrick
Systems Support Engineer
DOE Oak Ridge National Lab
Windchill is staying a Java-based application, but PTC has announced they are beginning to re-design certain parts of the application that were Java applets to HTML5 applets. This might be what the local support person was talking about.
Tim, Thanks. That explains what the person meant. I thank you for your timely response.
Dennis
Dennis,
at this link there are a lot of presentations from PTC Live 2014.
http://portal.ptcuser.org/p/do/sd/sid=2460&type=0
One of them explain the migration from applet Java to HTML5 applets.
