I trying to clone my production server for that i did the followed steps,
After completed the above steps i tried to start the windchill, but its not started. Herewith i attached the MS log file.
whether i followed the correct steps or anyone please suggest me the correct steps for that.
Waiting for your valuable reply!!!!!
There are a bunch of properties files and database entries that need to be changed. The only PTC supported method is to run the rehosting tool. Everything you did so far is fine, you just need to add that as step 6.
Thanks for your reply. In my case i have both source and target server has same host name. So i didn't change any properties in target system.
Whether i need to run a Re-host utility??
Can you explain little bit more. Am new to Rehosting!!!!
If you have any document kindly share to me if possible....
Sorry for the delay. If the host name did not change, and the file paths did not change, then you shouldn't need to run the rehosting tool. Looking at the method server log, it is complaining about a domain name not being properly defined in one of the properties files. Are you sure you have an exact copy of the entire Windchill directory on the source system? Might be worth repeating step 1.
Hi Tom,
Thanks for your reply. I just repeated the steps again. now its working fine.
