Windchill number - ProE parameter
ptc-1499334
Mike,
Update drawing and see if you insert the following parameters into your CAD
Drawings title block within Pro/E. Check-in + Publish your Drawing.
PTC_WM_NAME
PTC_WM_NUMBER
Hema Jatla | Datafrond LLC - <">http://www.datafrond.com>
Mike,
Isn't your number equal to the ProE file name. If the extension is part of
the number you can simply use &MODEL_NAME. If you want to exclude the
extension then make a new parameter such as PART_NO and add the relation to
your model (or start model) PART_NO=rel_model_name()
For the name you are correct PTC_COMMON_NAME is now hidden in Wildfire 3.0
but it works fine.
David
"Hema B Jatla"
<hjatla@datafrond <br="/> .com> To
'Michael Holifield'
03/04/2009 04:38 <->,
PM -
cc
Please respond to Subject
"Hema B Jatla" [solutions] - RE: Windchill number
<hjatla@datafrond -=" proe=" parameter=" <br="/> .com>
Mike,
PTC_WM_NAME
PTC_WM_NUMBER
