Community Tip - Visit the PTCooler (the community lounge) to get to know your fellow community members and check out some of Dale's Friday Humor posts!
X
Isn't your number equal to the ProE file name. If the extension is part of the number you can simply use &MODEL_NAME. If you want to exclude the extension then make a new parameter such as PART_NO and add the relation to your model (or start model) PART_NO=rel_model_name()
For the name you are correct PTC_COMMON_NAME is now hidden in Wildfire 3.0 but it works fine.
David "Hema B Jatla" <hjatla@datafrond <br="/> .com> To 'Michael Holifield' 03/04/2009 04:38 <->, PM - cc Please respond to Subject "Hema B Jatla" [solutions] - RE: Windchill number <hjatla@datafrond -=" proe=" parameter=" <br="/> .com>
Mike,
Update drawing and see if you insert the following parameters into your CAD Drawings title block within Pro/E. Check-in + Publish your Drawing.
