We're using Windchill 10.0 M030 with Wildfire 4 M220 (moving to Creo 2 this fall). Currently I have the publisher in Windchill set to publish drawings as pdf files. Works great, with one exception. The title block cells of the drawing where I have &PTC_WM_REVISION are blank. When the user has the drawing open in Pro/E it displays properly with the revision letter and when we "print" or save-as a pdf of the drawing from the Pro/E session it's fine. For some reason the Windchill publication process drops it / doesn't recognize it. Ideas? Is it something in the recipe settings or a config setting for the session of Pro/E that actually does the publication?
Erik
Figured out the issue:
