Does still exist the "undo" command in Windchill like in the old Pro/Intralink?
Because when I go in the "Events manager", in the slide menu on the top of workspace, only few events have the button "apply events" (in my case only the events "add") and anyway if I push one of those nothing happens in the WS.
Perhaps that command works only in a given situation?
At work I have version 10.1.
Hello
need to activate "frames" in your Workspaces
in Preferences/WorkGroupManager Client/Workspace Frame StackSize.
By default to 0. Set the number of "undos" you want to be able to do
regards
Hello
regards
Ok so I have frames set but how do you actually do the undo?
View all the events from the event manager and then click on the paper icon by the frame you want to apply.
