Version: Windchill 12.0
Use Case: I have a report that lists out a number of ECNs and how many reworks (trip count) per ECN there were. The table view of the report shows a new row for each incrementing trip count value. "Group by" doesn't seem to do the grouping by rows to consolidate the results.
Description:
The report template lists out the ECN number for a time range with it's trip count (number of reworks). The table itself has a row for each incremental value of the trip count.
Something like this:
| ECN Number | Date | Trip count |
| ECN-12345 | 1/2/23 | 1 |
| ECN-12345 | 1/3/23 | 2 |
| ECN-12345 | 1/5/24 | 3 |
Is there a way in the report template to group the rows by the ECN number so that for the example above I just get a single row like this:
| ECN-12345 | 1/5/23 | 3 |
Ideally I'm looking for a way of doing this without exporting out the table and then doing this in PowerBI (which works just fine).
Try removing the Role from the "Select or Constrain"
I have a report that counts the number of Windchill accesses of various users in real time.
The report uses the database COUNT function.
Obviously the count is impacted by the range used as the time period
Below are some examples of existing reports that use the COUNT function
How to Generate a report to get a count of users exist
How to create a report that counts WTParts in a specific context
Report listing all content counts by data format
Report for counting the Affected Objects in a Problem Report
Report to count the number of documents by different document types
Looks like you just want the maximum trip count? Try using the database function maximum. You'll need to define that in a sub-select if you go that route.
That's what I'd like. When I create the criteria, though, I get a "this table cannot be modified from a sub-select" for all of the tables".
In the sub-select you have to add the table from which you want to extract the criteria one more time.
That table will be colored white and not blue like the ones in the image you attached
I think that's the part I was missing - adding a new table in that sub-select. So step 1 done and now working... but failing in terms of result provided. Looks like that's on me (Work Item or Wf Assigned Activity is a unique ID each row so perhaps stepping up to the ECN level will give me what I want).
I made some progress with the COUNT function. Instead of using MAX on trip count, I counted the "Rework" vote on a task. The results aggregate by Role AND ECN, though instead of just by ECN - my end goal.
Select or Constrain
Criteria
Here I want to get the total count of Rework votes - regardless of role - in an ECN that is either Released or Resolved.
The subselect looks like this:
And I'm selecting the change notice ID:
Such that it's equal to the change notice ID that I'm counting reworks in... I think?
The result is the correct Rework count, but spread out over the roles for the individual ECN IDs.
How do I aggregate this last step without separating by role?
That did it!
