Actions.xml files are fine. A clean restart of the application worked and application is now up and running.
However we still dont know the RCA.
Any idea what would have caused this temporary issue?
Hi @paj1
can you provide full error from log? with the rows around?
If you search for the error on the PTC knowlage base you could have found following article with your error
CS381889 - Post upgrade unable to start the Windchill PDMLink 12.1
PetrH
Hi @HelesicPetr ,
Error is MS logs is.
java.lang.NullPointerException
at wt.access.AccessSelector.getQuerySpec(AccessSelector.java:346)
at wt.access.AccessSelector.getQuerySpec(AccessSelector.java:312)
at wt.access.StandardAccessControlManager.getPolicyAcl(StandardAccessControlManager.java:2342)
at wt.access.StandardAccessControlManager.getPolicyAcl(StandardAccessControlManager.java:4270)
at wt.access.StandardAccessControlManager._hasAccess(StandardAccessControlManager.java:10719)
at wt.access.StandardAccessControlManager.checkAccess(StandardAccessControlManager.java:7980)
at wt.access.StandardAccessControlManager.checkAccess(StandardAccessControlManager.java:416)
at sun.reflect.GeneratedMethodAccessor51.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
Also MS startup fails with error:
[NmActionService.initXml] com.ptc.netmarkets.util.misc.StandardNmActionService.xmlInit - Started InitializeXML With stax Parsing
FATAL [main] wt.method.server - MethodServerMain abort
wt.util.WTRuntimeException: java.lang.NullPointerException; nested exception is:
at wt.access.StandardAccessControlManager.hasAccess(StandardAccessControlManager.java:536)
at sun.reflect.GeneratedMethodAccessor34.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
Hi @paj1
Check if you have any customization actions in customAction.xml or customActionModel.xml
It seems that the the "com.ptc.netmarkets.util.misc.StandardNmActionService.xml" can not read some xml definition for Actions. There could be some xml parsing trouble,
Try to check the xmls if they are correct.
PetrH
Sometimes it happens. There can be some trouble with memory or temporary issue
If the restart solve the issue, there is no way how to get that info if it does not happen again.
PetrH
Thanks.
