Windchill\vaults\defaultuploadvault
danjdial
Thank you so much to Randy Jones, Venkata Kotra, and Matt Meadows for the
help.
To summarize use the File Server Administrator to clear unreferenced files
from the default cache and upload vaults. If that process sets your vaults
to read only which it does in 9.1 m040 then be sure and uncheck their read
only attribute.
Again folks, thank you for your help.
Sincerely,
Dan
On Tue, Apr 30, 2013 at 12:28 PM, Kotra, Venkata 6/20/2013 <
Venkata.Kotra@sbdinc.com> wrote:
> Hi Dan,****
> Windchill\vaults\defaultuploadvault is replica vault for the master and it
> should be a temporary storage for replication purpose..****
> As per PTC..There should not be any files referencing from this vault..To
> confirm that we need to select this vault from vault configuration and use
> remove unreferenced files(move) option.****
> If you see that there are still referenced files from this vault..then
> schedule a replication job which replicates data from this vault to master
> vault..****
> We have this replication job executes daily once..****
> Please let me know if this helps or you need more support on this.****
> regards****
> Venkata Kotra*║*Sr.Analyst, Engg Systems *║*IS, HHI****
> *Tel : 949-672-4018 | Mobile : 408-771-7739*****
> *[image: cid:image003.gif@01CDDC3A.2CA9ECC0]*
> *From:* Dan Dial [
0 REPLIES 0
