Windchill
hsha1102
Windchill
Thank you for sharing your knowledge. mypascoconnect
8 REPLIES 8
BenLoosli
(To:hsha1102)
Did you install the database first?
You must do this before installing Windchill and configuring it.
MikeLockwood
22-Sapphire I
(To:hsha1102)
Attached for reference is an example install of Windchill 12 on a Windows 10 laptop.
KM_9435582
(To:FT_9640127)
Hi. Do we need Windows server to install windchill ? or will it be possible to install on Windows 10 ?
You can install Windchill on Windows 10 for testing purposes, but it is not supported for a production environment.
You can find this in the Windchill Software Matrices.
KM_9435582
(To:AndyHermanson)
Yes i was trying to install in Windows 10 for test ( havent installed database yet ) , i ran the install script for solution installation and got this error. The install folders ( software ) all start with MED-60 .. , not sure which one to run first.
BenLoosli
(To:KM_9435582)
You must install the database and configure it first.
The MED* files are zipped and need to be unzipped before running the PSI.
KM_9435582
(To:BenLoosli)
yes installed Oracle and configured it , also verified with sqlplus the database is working. But when i run the solution  ( setup.vbs ) still get the same error.
