All -
I saw some old posts on this question, but no response: Our publish monitor shows all our ProductView jobs are failing. They started failing yesterday, so I reloaded/restarted the process and rebooted the worker. This morning, everything was running successfully for a while, and now they are failing again. I went to restart the process, and its status shows 'Fails to Start'. What does this mean? (beside the obvious...) Any ideas what happened?
Thanks in advance -
Chrystal Johnstone
Red Dot Corporation
I would also suggest few more ,
First try telnet'ing from the master node to the CAD Box.
Secondly try to communicate via telnet and check if it is reflecting in statusLogs .
Third , check for the ALIAS names from the host file.
I assume that Worker configuration was not properly setup.
Sriram Rammohan
There is a point in Bob's sugestions. The logs will give you the root cause of the issue. try uploading / studying the Worker, helper & monitor .log (found in CAD Worker setup directory) for permenant fix.
I am guessing the configuration is correct, as; if it would have been incorrect, there would be no publishing at all. But in your case few jobs are publishing appropriately.
Does the Pro/E on CAD worker have a dedicated licence ? Make sure you are not falling short of licence as well.
~ Vaibhav
In Reply to Sriram Rammohan:
First try telnet'ing from the master node to the CAD Box.Secondly try to communicate via telnet and check if it is reflecting in statusLogs .
Sriram Rammohan
