You can create a Custom Task Delegate and achieve the same.
Regards
-Prajeesh
Is it possible for you to share the whole workflow? I am also trying to implement the samething.
Sitanshu
I was asking that, if we can get the snapshot of the workflow image.
Workflow for the following problem:
"Workflow Approroval activities with multiple participants wait until all
of the participants provide vote, if 'All' is chosen as required in the
template. If one of the approvers Reject ,then activity should be completed and sent back to initiator without
waiting for other approvers votes. Whereas it waits for all the approvers to vote if no one rejects. We are using a sync robot with class based event for
this customization which is causing huge performance issue."
