Workflow History Viewer
rleir
Hi team
The help page linked below says there is a Workflow History Viewer utility :
$  windchill wt.workflow.engine.WfMonitor
We have WC 12.0.2, and I get 'ClassNotFoundException'
Is there a typo in the class name? Do I need to add to the classpath?
Rick
https://support.ptc.com/help/wnc/r12.0.0.0/en/index.html#page/Windchill_Help_Center%2FWFChp_WFHistoryViewerUse.html%23
HelesicPetr
(To:rleir)
Hi @rleir
I guess that PTC remove this utility from the Windchill.
I can't find the class and any similar utility in the Windchill 12.0.2.1
PetrH
HelesicPetr
(To:rleir)
Hi @rleir
PetrH
rhart
(To:rleir)
I gave it a try on PDMLink 11.1 M020 and got a null pointer exception
E:\ptc\Windchill_11.1\Windchill>windchill wt.workflow.engine.WfMonitor
                Workflow Monitor - Main Menu
        Existing Workflow Processes
        >> WARNING: The ManagerService is not initialized!  This can be caused by:
1) Attempting to invoke a server only method from a remote client
2) Attempting to invoke a method on a service from the constructor or static initializer of another service
Exception in thread "main" java.lang.ExceptionInInitializerError
        at wt.workflow.engine.WfProcess.getName(WfProcess.java:1431)
        at wt.workflow.engine.WfMonitor.processToString(WfMonitor.java:505)
        at wt.workflow.engine.WfMonitor.main(WfMonitor.java:100)
Caused by: java.lang.NullPointerException
        at wt.access.AccessControlServerHelper.<clinit>(AccessControlServerHelper.java:85)
        ... 3 more
HelesicPetr
(To:rhart)
Hi @rhart
Windchill has to be stopped before you start the utility
PetrH
rleir
(To:HelesicPetr)
Hi Petr
I stopped WC, but that did not help.
Error: Could not find or load main class wt.workflow.engine.WfMonitor
Caused by: java.lang.ClassNotFoundException: wt.workflow.engine.WfMonitor
Rick
