Workflow Timer Robots
dgraham-4
PDMLink 8.0 M020
We are finding that any workflow Timer robot that is running when the MS
is restarted will not run properly after the restart. The behavior is
that the Timer still appear as Running in the workflow however when the 30
minutes, or whatever it is set to is reached the workflow does not
continue.
Does anyone have an experience with this and what did you do outside of
not using Timers?
David
0 REPLIES 0
