To add to the previous replier:
The routing options on the left are all mapped to the string variable
"result".
So you need to make the conditional field apply a value to result in some
manner. This can be as easy as just having another variable equal result,
for example
If (myIteration = 5){
result = "Repeat";
To get the IBA value, you can do something like was described by Dax, I just
thought I'd reply with something a bit more simple.
If you have any more questions, I have a function that can do similar things
to what he described as well, a little cleaner
Patrick Kurtz
Consultant
ProductSpace Solutions Inc.
"Your Products to the Nth Power"
630.495.2999 Ex 8110
On Tue, Mar 10, 2009 at 2:11 PM, Stavish, Richard <
rstavish@sargentcontrols.com> wrote:
> Windchill Admins,
> I have a custom workflow that I am trying to add a conditional
> statement to one of the activities or a conditional router node. I would
> like to use a particular attribute to control the path of the workflow using
> the conditional statement. The attribute is attached to a WTDocument
> SubType which is also the PBO.
> If I open the activity in the Workflow Process Manager and go to the
> Routing Tab and change the Routing Type to Conditional. Now I am able to
> type in my three conditions, Repeat, Revised, or New.
> I am not sure where to go from here.
> Any suggestions
> Thanks for you help
> Rich
> *Richard Stavish** **
> *Pro/E System Administrator
> Sargent Controls & Aerospace
> E-mail:
> Office:
> Fax:
> RStavish@sargentcontrols.com
> 520-744-1000 Ext. 570
> 520-744-7529
