Does anyone know how to disable the windows that pop up when doing some actions like saving and uploading? These notifications pop up at the bottom right corner of the cad tool.
From Help Docs:
message.slider.timeout
Controls the duration that a pop-up message window stays on the screen.
• 10 (default)
• 0 (disables slider window)
Enter a numeric value in seconds.
this should be in the wgmclient.ini file.
From Help Docs:
• 10 (default)
