Workspace cleanup
BenLoosli
Workspace cleanup
Preparing my users for an upgrade from Windchill/PDMLink 9 to 10 and want some feedback on a best practice.
As part of the upgrade, all workspaces MUST be deleted before I do the upgrade. What is the cleanest method for the users to remove their workspaces? I have asked them to do the 3 steps below. As I was thinking some more, is step 2 needed for a clean workspace delete? Will deleting the workspace only cause issues with marking the files as being removed from the workspace?
1) Check-in or undo checkout all files
2) Open each workspace and remove all files
3) Delete the now empty workspace
Hello ,
There is a clean-up tool (utility) avaialble with PTC which can be used to automate the WS clean up.
Sriram Rammohan
Its a tool called windchill com.ptc.cust.wsdelete.DeleteWorkspaces.
You can also customise based on your req. however the core logic remains same ,
EPMWorkspaceHelper.manager.getWorkspaces(localWTUser, null);
wher localETUser is the user whose WS needs a clean-up.Prior to deleting you can also purge/delete the contents in the WS.
Sriram Rammohan
