I added a couple of settings to a new Windchill 12.0.2.8 system for wt.FV settings. When I use xconfmnager -d on the settings, 2 of them show as being in site.conf and wt,properties with the target being codebase\wt.properties. The other 2 only show as being in site.conf but they do have the target set to codebase\wt.properties. Yet when I open wt.properties, I can find all 4 settings and set to my values.
Anyone else seen this odd result?
Hi @BenLoosli
It happend to me if I missspelled the wt.properties file name with different file extension for example .proprties 😄
PetrH
edit:
I missunderstand your problem
The -d as a describe action shows all settings defined in XCON files even though the values are not propagated to the target properties files.
So be sure to use -p to propagate all values.
I can advice always control the target file if the value has been propagated.
Been there, done that ☺
The system will create a new file with whatever name you give it.
In my case, I can open wt.properties in Notepad and see the 4 file vault settings, so I know they are in the right files, just xconfmanager does not display that fact. Xconfmanager does show thw line of the setting in the site.conf file. 2 of the settings display right, 2 don't.
what xconfmanager -d shows to you? the last setting from xconf.properties files? or actual target values?
As I know that xconfmanager -d do not shows the actual values from target files but the values from xconf files.
PetrH
I missunderstand your problem 😄
PetrH
