Just a reminder that we are running a survey on your transition from legacy Change links to Flexible Change Associations. We introduced the Flexible Change Associations in 11.0 with tools to help transition from the legacy to new links including being able to run in Mixed mode where anything new is Flexible Mode and your older running processes can complete in Legacy mode (to be converted once complete)
In the next major release of Windchill our goal is to remove support for the Legacy links - the survey is to understand and gain your feedback as to where you are in the process. Thank you for your input - the link to the survey is:
Flexible Change Association Survey
We plan to close the survey on May 31st
