Zertifikate abgelaufen
HJ_9681957
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.1.2
Hallo zusammen,
die Zertifikate ist abgelaufen, könnt ihr Hilfen, die Erneuerungszertifikate einrichten? danke
Here are the errors that I faced
net::ERR_CERT_DATE_INVALID
It depends on how your system admin or IT originally set them up. If it was self-signed, then there are are straight forward commands and steps to run to generate new certificates. If there were obtained from a certificate authority, you need to get them renewed. Generally speaking, this involves replacing the certificate files in your Apache configuration as well as adding them to your Java keystore. What operating system do you have?
https://www.ptc.com/en/support/article/CS404891?source=search
https://www.ptc.com/en/support/article/CS267795?source=search
Please provide more details to clarify the scope and type of changes...
https://www.ptc.com/en/support/article/CS357113
Are these public/in-house generated or self-signed certs?
Just Windchill or including Navigate/PingFederate certs?
Are the file vaults on another server?
If Windchill only and using public/in-house generated certs...
1. Import new cert chain into Java's jssecacerts.
https://www.ptc.com/support/article/CS348294
2. Replace cert files in Apache's conf folder.
3. Import new cert chain into Windows keystore on app server and file vault server.
