auto-associate
Highlighted
Alexandrite
auto-associate
Hi pros,
Is there a way to make auto-associate checked by default? And bonus question is:
why would you have it not auto associated?
Appreciate your help!
Dmitry
Highlighted
auto-associate
You can set this within the Preference Manager.
Hema Jatla | Datafrond LLC - <">http://www.datafrond.com>
Highlighted
auto-associate
Yes. Depends on what version you are on. When I checked 9.1, it's a
preference. In 8.0, I was able to edit a javascript file to check it by
default. In our case, we always have it on. Users are lazy sometimes and
would forget to check it. Its better to have them create a WTPart always
then never create one at all. I do turn off the option sometimes when I
am checking in a model that I want to be just a model and not report to
the WTPart Structure.
Highlighted
auto-associate
Still, that is only applicable to Custom Check-in not Auto- Checkin since Auto-Check bypasses the HTML UI that uses the preferences.
Well, for WTPart auto creation, it is normally required when you work with prodcut structure. So, if you don't utilize it, you may not need to turn it on.
Highlighted
RE: auto-associate
But auto-checkin, by default, does not auto-create wt.part. It would associate one if it exists.
