automatic JRE version selection
dgraham-4
We need to be able to run JRE 1.4 for PDMLink (8.0 M020) and JRE6 for
other apps/web pages. I'm thinking if the JRE version can be selected
based on the web address that would fix our problem.
For example, if the address is
5 REPLIES 5
Well since Windchill is frontended by apache and backed by its own tomcat instance, you could set up another application server and simply redirect different context roots there.
-Thomas R. Busch
Sr. Software Developer
Stryker Instruments
(269) 323-7700 x4014
tom.busch@stryker.com<">mailto:tom.busch@stryker.com>
One more thing - if you can upgrade to 8.0 M050 I believe it at least supports Java 5, which might give you enough of a compromise.
-Thomas R. Busch
Stryker Instruments
jessh
(To:dgraham-4)
The Java 6 Plug-In is supported with R8 as of M040, so one solution
would be to move to R8 M040 or M050.
For Java 6 Update 10 and higher in MSIE 6 and higher and Firefox 3 and
higher specific applications can select their own specific Java Plug-In
versions and each application will get its own version without
conflicting with others as in older versions. This only works for Java
6 Update 10 or higher JVMs to the best of my knowledge, though.
[As someone else noted with R8 M050 one can also run Java 5 on the
server for better performance, monitoring, etc, but that's a separate
and unrelated decision point.]
Jess Holle
Thank you to all who replied.
We found that it we simply uncheck the option below all works well.
David Graham
CAx/PDM Administrator
Emhart Glass Manufacturing Inc.
123 Great Pond Drive | PO Box 220 | Windsor, CT 06095-0220 | USA
Telephone +1 (860) 298 7377 | Telefax +1 (860) 298 7397
Mobile +1 (203) 376-3144 |
jessh
(To:dgraham-4)
As noted on the R8 M050 platform matrix there are TAN's/TPI's on
getting Java 6 Update 10 and higher to work without unchecking this
option (which generally provides greater stability, higher performance,
etc).
