automatic re-checkout
JohnMattson
2-Explorer
When doing a "check in" from your workspace (or directly from Pro/E), is
it possible to have the part automatically "re-checkout" to yourself
again, so that you can immediately continue making changes?
Thanks, John
This electronic message including any attachments ("Message") may contain information that is privileged, confidential and/or exempt from disclosure under trade secret and other applicable law. If you are not the intended recipient, notify the sender immediately, permanently delete all copies of this Message, and be aware that examination, use, dissemination, duplication or disclosure of this Message is strictly prohibited.
On 09/03/10 14:32, John Mattson wrote:
> When doing a “check in” from your workspace (or directly from Pro/E), is it
> possible to have the part automatically “re-checkout” to yourself again, so that
> Thanks, John
In PDMLink 9.1 M050 when checking in from the workspace you can do this.
In the first window that comes up after selecting check in simply select
the object(s) and then "Edit | Keep Checked Out"
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
Thank you Randy and Sean.
During the "Check In" there is an option under "Edit" --> "Keep Checked
Out"
You will need to put check mark in the box of items that you want to apply
this to.
Robert Altman
CAD Systems Manager
General Dynamics Amphibious Systems
Expeditionary Fighting Vehicle Program
703.490.7533
John Mattson <->
09/03/2010 03:32 PM
Please respond to
John Mattson <->
To
cc
Subject
[solutions] - automatic re-checkout
When doing a ?check in? from your workspace (or directly from Pro/E), is
it possible to have the part automatically ?re-checkout? to yourself
Thanks, John
Site Links: View post online View mailing list online Send new post
via email Unsubscribe from this mailing list Manage your subscription
Use of this email content is governed by the terms of service at:
