build associated part, however, in an assembly BOM, the same part is showing as unassociated
AnthonyC
Initially posted in this topic
i am hoping you can help me, i am able to build associated part and view it on a single level as build when comparing to the part structure, however, in an assembly BOM, the same part is showing as unassociated. Is there a step i am missing?
the set up was not done correctly from our system and was fixed by the admin from the provider. thanks everyone for contributing.
Hi Antony,
Please check when you compare the WT Part Structure & CAD Structure both versions are the same. If it's not apply the "Set for build".
For your more information: https://support.ptc.com/help/windchill/r12.1.2.0/en/index.html#page/Windchill_Help_Center/WorkingWithCADandPartStructures/TDDBuild.html
Amir
i made a seperate post to try solve this.
https://community.ptc.com/t5/Windchill/CAD-Doc-vs-Part-BOM-sub-assemblies-not-rebuilding/m-p/912748#M75992
i am unable to set for build from the menu. so far, it seems our windchill/ creo configs are not running correctly. my versions are matching correctly,
