Version: Windchill 11.1
Use Case: the software can not run, the message is: License initialization failed: flex initialization error. (-97)
Description:
Article - "License initialization failed : flex initialization error. (-97)": https://www.ptc.com/pt/support/article/cs313442
dear
thank you for your support. I found file (ptclmgrd) as shown in the image attached.
BR:
Hello @AA_11026082,
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
