can't undo check out/summary
TracyWillis
I'm running again
- Another user suggested to delete the .wf local cache and make a new
connection to the server.
Did that . Then I reconnected & synchronized the WS.
The files still didn't show up in my workspace but I'm pretty sure it
helped because this time when I tried to delete them I got an override
option to undo the check out.
I had tried that before but didn't get that option. I know it's not the
best solution but it works in this case. These files were new
yesterday and aren't tied to any history or another assembly file yet.
There is a file backup of them I had saved before all the problems
started and I'm just going to work those over.
Thanks for the help guys
Tracy Willis
Designer / Drafter
Cook Urological, Inc.
11OO West Morgan Street
Spencer, IN 47460
(812) 829-4891
(812) 829-1801 (fax)
Confidentiality Note: The information contained in this e-mail is
strictly confidential and privileged information which is intended for
the use of the above addressee(s) only. All other use is strictly
prohibited. If you are not the intended recipient, any review,
distribution or copying of this document is strictly prohibited. If you
have received this e-mail in error, please notify the sender immediately
and delete the document from all computer systems, or notify Cook
Urological at (812) 829-4891.
0 REPLIES 0
