From the windchill shell, run the following command
wt.vc.wip.ObjectAlreadyUnlockedCleanUp –relock
and then do a undo checkout. I have used this option in 8.0 M050, I am not
sure if it will work for M030. You can give it a try.
Rajesh Balasundaram
Alfonso Medina <->
06/16/2009 12:52 PM
Please respond to
Alfonso Medina <->
To
cc
Subject
[solutions] - cannot delete checked out item
The error for Un do check out is “The object was already unlocked.”
I also try to remove the part, check it in etc. I get another error on
check-in “java lang null point”
regards
Alfonso Medina O.
Mechanical Engineer
